Tom H
Does anyone know of a good source for front strut mounts? It looks like the only one currently available is the e12 mount, p/n 31331101663, which others have said is interchangeable. The prices I'm finding online seem wildly high.
So, do you think my mounts could be made serviceable? I made this video a day after buying my coupe with the wheels off the ground. Since then the car has been patiently waiting for me to get on with its restoration so I'm not driving it like this.Good point @bavbob, unless the rubber is cracked and broken, a good clean out and bearing re-pack is not difficult.
This is a good point. Thanks for bringing it up. I see K-MAC has a few options:From a price and utility perspective it might be time to consider negative camber plates as an option. I believe that Carl Nelson may have some (I haven't used) and KMAC in Australia sells some as well.
k-mac-camber-kits.com
I had considered this, as my rubber is decent, but on one of mine the strut bushing is not square with the rest of the mount, and I think it might be causing binding when turn.Good point @bavbob, unless the rubber is cracked and broken, a good clean out and bearing re-pack is not difficult.
Ah, so they aren't like adjustable like some front wheel bearings, or the bottom bracket bearing on a bicycle. Thanks for the confirmation.That looks pretty loose, I doubt that grease would take up the slack that I am seeing between the bearings and the race.
