For Sale: 1974 3.0 CS Coupe
E9 Forum thread with description and pictures of work performed.
I purchased this coupe in 2014. Shortly thereafter I enlisted forum member Sven Larsen to help with an extensive engine, suspension and driveline rebuild and upgrade. The old 3.0 carbureted engine was exchanged for a 3.5 fuel injected custom built engine with MegaSquirt 3. Paul Burke custom cam and custom pistons. The goal was to upgrade but keep the car looking as stock as possible.
Flicker thread with photo album
https://www.flickr.com/gp/163302197@N08/E052jM
E9 Forum thread detailing rebuild
https://e9coupe.com/forum/threads/driveline-suspension-engine-redo.17451/
Color: Granatrot
Mileage: 126,000 – 4,500 on new engine.
The new engine is amazing! She’s fast, pulls really hard in every gear with a beautiful and aggressive exhaust note.
Below is a list of the work completed over the past 4 years and while she’s certainly not a perfect 100 point car I feel she one of the best maintained driest and fastest coupes out there.
Car will be available for purchase through BaT auction site in coming weeks.
Rust:
The car is as close to rust free as I think you can get these days without a ground up rotisserie and while I don’t want to say 100% it’s close. I believe it spent its life in California, and Arizona before moving to Seattle.
Body/Exterior:
An almost rust free extremely dry body
Coupe King bumper conversion
Coupe King Replica Alpina staggered rims
Painted engine bay (while engine was out).
Engine Rebuilt By Motor Sport Seattle
M30b34 block & b35 head. Block bored to 1st oversize.
Custom Paul Burke 10:1 pistons, N21 Paul Burke cam, valve regrind, new valve guides, crank grind, all new bearings. Complete rebuild.
3.0 CSi Intake parts and oil pan clear coated with high temp coating
Modified intake manifold stubs to fit larger head intake ports.
Modern injectors cleaned and tested (hose adaptors from La Jolla)
All new fuel hoses
K&N Air filter currently on car
Electronics:
Megasquirt 3 full featured ECU MS3 board with sequential fuel injection
Custom wiring harness in engine bay for EFI
New battery
New in-tank fuel pump
Megasquirt box located in glove box
Drive Line:
5 Speed Gertrag (w/OD)
Replaced rear seal
M-type guibo installed
Replaced rear wheel bearings
Installed rebuilt LSD
Installed reinforcing plate kit from Coupe King
Lengthened/rebuilt/rebalanced propeller shaft
Disassemble/cleaned/re-greased both rear axles. Replaced all boots.
Suspension:
Carl Nelson springs (on car when purchased)
Bilstein shocks (on car when purchased)
Installed upsized sway bars (28mm front & 22 mm rear) and bushings.
Replaced center steering linkage and both tie rod ends.
Replaced front rubber compliance bushings.
Replaced control arms.
All suspension metal parts powder coated (front engine frame, rear frame and arms, wish bone links, and other miscellaneous brackets)
Replaced both rear suspension bushings and bushings in rear trailing arms.
Replaced rear diff bushing.
Brakes:
Rebuilt all brake calipers & new pads.
Replaced e9 with Tii brake booster/Modified rod length
New stainless hard brake lines fabricated (with additional length for Tii booster)
Replaced rear proportioning valve with one from La Jolla
Exhaust:
Custom stainless steel exhaust
Mid 80’s cast iron manifolds –high temp ceramic coated
New 1-3/4” stainless downpipes ceramic coated converging to 2-1/2” pipe
4”x18” center resonator (Magnaflow)
5x8x24 oval muffler (Magnaflow)
2-1/2” polished stainless tail pipe with polished tip.
Cooling:
Radiator re-cored with 2-row high efficiency core.
New fan clutch & water pump with smaller pump pulley
New belt
All new coolant hoses
New thermostat
AC
New compressor & mounting brackets.
Replaced old fan with new 14” electrical pusher fan (controlled by MS3)
New belt
Steering:
Power steering pump rebuilt
Power steering gear box rebuilt
New belt
New low pressure and high pressure hoses
Interior:
Existing seats recovered in black leather front and back
Seat Chrome refinished
Stainless door sills polished
Rear deck lid refinished
Gas Tank
Refurnished inside and out.
Color: Granatrot
Rust:
Body/Exterior:
All new fuel hoses
Electronics:
New battery
Drive Line:
Replaced rear seal
Suspension:
Brakes:
Exhaust:
Cooling:
New belt
New thermostat
AC
New belt
Steering:
New belt
Interior:
Gas Tank
