Fumes are always in the trunk. Now I know why. Do you have the 2 rubber plugs?Are you getting fumes in the trunk from the missing rubber plugs for the boot?![]()
Thomas, The wide part goes to the top. The narrow part goes to the bottom. These are for the right side. Measure the width from the right crease to the folded edge on the left per my photo. If it is 4" (10.3 mm), the spacer is too wide to fit the E9 and is probably for the E3.Hi Drew,
so I got you puzzled?
In fact these are all the same, all for the left side:View attachment 189716
Thomas
There are rubber plugs?Are you getting fumes in the trunk from the missing rubber plugs for the boot?![]()
Carlos--Unditch them!! You made the wrong measurement! Look at my photo. Take a measurement 90 degrees from your photo. The critical measurement is from the white liner to the fender. Measure from the central fold to the other direction where the spacer folds against the fender inner wall."The measurement from the top edge that tucks under the white liner to the folded edge should be about 4 1/4" to fit in the E9 trunk"
Sorry then but ones I found must be for a NK or something else then.
I measured short of 3 1/2" between central fold and top of curved side (press on trim) so I ditched them.
Hi Drew, you are right! Thanks so much!Thomas, The wide part goes to the top. The narrow part goes to the bottom. These are for the right side. Measure the width from the right crease to the folded edge on the left per my photo. If it is 4" (10.3 mm), the spacer is too wide to fit the E9 and is probably for the E3.
Better yet, take the spacer and try to fit it into the E9 trunk. The ones I have will not fit in my coupe.
Hi Drew, I may find these plugs for you!Fumes are always in the trunk. Now I know why. Do you have the 2 rubber plugs?
Now that you found a replacement I sourced the originals.I found substitute plugs that fit perfectly. Pics below. I bought a box of plugs for holes in the inner fenders in the engine bay several months ago. I hope my fuel smell will be gone when I open the trunk. The M12.07 fits the holes.
Hi guysHi,
seems to be elephant skin day today?
Three pieces available, 45€ each plus shipping from Germany.
Thomas
