FS. One Set Left and Right E28 Window Motors for E9 Upgrade
Drew Gregg
Ft. Lauderdale
I bought these from Koopman. They must be installed by cutting the door metal to fit correctly. There is a post on how to do the installation here on the forum. When the shop I use removed the door card, we found the driver side already had the E28 motor,but not correctly installed. the door frame had not been cut to flush mount the motor. It put a slight bulge in the panel and the gears did not align correctly. When these motors are installed and correctly wired with relays, the windows will work much better than before.
