In a few weeks I can get some measurements
Thank you Markos for creating this dedicated post on our linkage solution for the M30. It took us over six months of design and prototyping to create a linkage that looked OEM like the 2002 ti version and still retained the robustness, and ease of installation and maintenance of that original. And it is also much shinier!!
An interesting fact about 99% of the side draft carburetors made during our vintage cars era is that they all had the same symmetrical mounting holes for the carb to manifold mating: Solex, Solex ADDHE. Solex Mikuni, Dellorto, Weber, ..... And, because the throttle lever (front carb) must interface with the balance lever (rear carb) the distance between the carb mounting studs has to be very close for all manifolds. I've never test fitted DCOEs to a VGS manifold but I can't see how it could be that much different unless the throttle/balance levers are greatly modified.
So, when you get a chance, if you could just measure the distance between the mounting studs for the 1 to 2 and 2 to 3 carbs, that will tell the story. I have test fitted the M10 version of our Ultimate Side Draft Linkage System on Korman, IE, Warnerford, Cannon, KarznPartz, OEM (both NK and 2002 ti), .... and, again due to the predicated geometry, fitment is no issue.
Here are some pics and a link to our M10 version for comparison:
The Universal DCOE System works with any one- or two-piece manifold including OEM, IE, Cannon, Korman, Warnerford, …. This is the best System for most Side Draft conversions including those with the DCOE choke mechanism installed. $265 plus shipping. NOTE: DOWNLOAD THE INSTALLATION TIPS SHEET...
www.2002sonly.com
