FS: Various parts - interior, 5-speed bits, hardware, brakes and more
CharlesJ
Arlington, VA
Have a number of parts I am clearing out. All prices are plus shipping. Have price now for some and will be adding more prices shortly
  • Air Cleaner Housing - $125
  • NOS Wheel Center Caps, most still in bags - $300
  • License plate center panel, needs work - $30
  • Side grills, need work - $25 for both
  • New Front Caliper (2800/E3 Only) - SOLD
  • Used 3.0cs/csi front and rear rotors set of four, minimal use if at all, but are quite old and had some rust. Can easily be turned to restore - SOLD
  • NOS accelerator pedal, still in original bag (older style) - $100
  • NOS front and rear caliper rebuild kits - SOLD
  • New W&N full rear axle hardware kit - $80
  • Dash top, fair condition - $120
  • Dash gauge cluster surround, some minor cracks - SOLD
  • Upper dash aluminum trim, good shape w/very minor surface scratches - $200
  • New, mostly OEM five speed parts (See picture with part numbers. -ALL SOLD
    • Used OEM 5 speed fork - $25
  • New front control arm bushings x4 - SOLD
  • Pile of sway bar bushings - SOLD
  • Used front tension strut/control arm link - $70
  • New W&N batter terminal - $25
  • Chrome plastic seat mount trim (only one) in good condition
  • Original side mirror, missing mirror retainer, fair condition - $25
  • NOS wheel shaft seals. - SOLD
  • OEM hella horn - SOLD
  • 14x6 +22 OEM turbine wheel - $150
  • Original steering wheel - $300
  • NOS interior sound insulation, various pieces. All are soft and the foam is in great shape. Only the large one needs a tiny bit of work with spray adhesive between the rubber and foam. Let me know which you want and will get the price. Most of these are NLA
  • OEM fuse block with cover ('73 and earlier) - $100
Here are more pics of the NOS sound insulation and wheel center caps
I could use the font and rear rotors, the brake caliper and the brake caliper rebuild kits
I guess I also need the suspension bushings and the sway bar bushings
