Does anyone know the fuel hose sizes in a CSi engine off the top of their face? Replacing the fuel filter and might as well replace all of those braided hoses while I'm at it.
When I replaced the fuel hoses on my car, I used the newer BMW fuel line (no braided cloth on the outside). It's 8mm inner diameter and 13mm outer diameter.
While you at it, might as well replace the hoses that connect between the fuel tank and pump.
In addition to a fuel return 8x13mm hose that connects from the tank to the underbody steel line, there is also a 12x18mm infeed hose connection from the fuel pump to the fuel tank suction device. About a meter is needed.
