Fuel Selection
Stan
Newmarket, New Hampshire
Question:
What grade of fuel does everyone use with a carburetted CS?
I have been running regular and it seems to work fine.
Stan
Fuel
Stan,
I use Premium, in California it is only 91 octane and it helps prevent the ocassional run-on when shutting down the motor.
US 3.0 engines only have 8.3:1 compression, so regular works just fine.
All 2.8s and rest-of-the-world 3.0 have 9.0:1, while CSi's have 9.5:1 and should use premium.
Hi Stan,
I have been running my 1971 2800CS on 91 Octane (dual Weber set-up) with great success. The Weber’s are a though set-up and I think the 91 keeps it a bit cleaner and helps to maintain proper timing with decent combustion. But that’s with the timing set at 18* BTDC at idle and without the vacuum advance connected…so go figure?
Greg
