Full retrofit of AC reproduction system in a E9
stormhunter
New Member
Bucharest, Romaina
Hello,
As some of you may know, my E9 journey began not too long ago. However, my quest to retrofit AC to non-AC cars has been going on for a while now since I did this to a couple of my cars and also for a few customers of mine.
As I was finishing the retro fit on my now ex-E24 I decided to sign up on this forum and immediately started searching for solutions to chill the interior of the E9. My worries came true when I discovered that as was the case for the E24, retrofitting AC to an E9 required acquiring a system from a donor car or picking parts off eBay and such. (I know there is another commercially available option out there but in my opinion it is very expensive). All this for the performance of the system to be limited by an antiquated interior fan and evaporator design which was the case for my E24.
Searching the forum I came across @Lucas 's endeavor to create a from-scratch system for our beloved E9's that didn't come equipped with AC from the factory. I contacted him to find out more about this project and long story short, last week I received one of the first complete kits from him.
In this thread I aim to showcase what the kit contains and the process of installing it in my 2800CS to the best of my abilities as well as test the performance of the finished product. I haven't done a write up of this scale before so please let me know where I can improve :). I will be adding posts to this thread as the installation goes on. I would also like to disclose the fact that in the future I will be offering this installation as a service for anybody interested.
Chapter 1 : Preparation
If you are planning on getting this kit professionally installed any reputable shop of your liking should be able to complete this job.
If, however, you are planning on tackling this job by you own there are a few things to take into consideration before starting the install.
1. Make sure you car has adequate cooling since the condenser will kick up heat and my possibly overwhelm your cooling system
2. You are adding a few large consumers such as the auxiliary fan and the interior fan for the evaporator to your car and you should upgrade you alternator. An 80A unit should do the trick
3. Check if your car has the means to drive the AC compressor. In my case the crankshaft pulley had only one slot so i had to source the appropriate one for this application
4. You will need to get in touch with an upholstery shop and an AC specialist. Because Lucas wanted to design to kit so that it will fit any E9 he left it up to the end user to choose in which way they wanted their center console upholstered and what routing to have for the refrigerant lines underneath the bonnet, hence this step.
Optional but recommended: Grab a copy of "Just Needs a Recharge" by Rob Siegel. It is a great read and insight on how the systems on our cars work.
That's it in terms of prep work, everything else comes in the kit supplied by Lucas. I took some photos of what came in the boxes so you can see for yourself (the compressor bracket hasn't arrived yet but rest assured you have everything else you need to get up and running with cooling your car)
Chapter 2: Disassembly and "dry test fit
Since it's my first installation of this kit I wanted to do a test fit of the evaporator assembly and center console before sending the latter to get upholstered.
To do this you first have to take apart the lower portion of the dashboard as well as your old center console. I haven't included a detailed teardown since I'm sure you can find better write-ups or videos for that.
The new evaporator core is mounted on a baseplate that bolts in the factory holes for the old console. Pictured bellow you can see the aforementioned base and evaporator mounted.
It is important to do a test fit with only the base attached to the transmission tunnel in order to mark out the hole you will need to drill for the condensation drain.
Since there aren't 2 cars that are exactly the same to the millimeter all the parts included in the kit have slotted holes where they attach to each other and the car so a perfect fitment can be achieved on whatever car you are installing it on. (withing reason, of course)
You will notice that I also took out the heater core on my car. I did this since I am also rebuilding it while I have everything out, it's not a mandatory step but may help with installing the intermediate piece . If you wish to do it you can find a great write-up here : https://e9coupe.com/forum/threads/diy-heater-unit-rebuild.38896/
Afterwards I added the console just to see how everything fits and sure enough it lines up perfectly
The next step is to send the sides of the console and middle piece to get upholstered (you can transfer the silver ornaments from your old one).
This week I will tackle some work under the hood mounting the condenser, fan, drier and mapping the layout of the lines while everything is getting wrapped in leather. I will update you as soon as I make some more meaningful progress.
I also wanted to give you some first impressions of the kit and quality of the parts manufactured and provided by Lucas.
I really like the quality of the prints. We do offer some small 3D printed parts for our customers such as clips and connectors but the quality of design and filament used here is on another level. Considering the effort that goes on in designing such a system I think the pricing is very fair and everything that was promised has been delivered. I also very much like the fact that variation of each chassis has been taken into account with the inclusion of slotted holes that give adjustability and the inclusion of the spirit level on the evaporator box.
I hope you enjoyed the read and photos, will keep you posted! (of course, any feedback is welcome)
Felix
