Fuse box door
BarryG
Gents, My door keep opening when i'm driving.The hook on the button lost it's spring.
Any fixes?
advice on taking it apart.
real oem shows a lock /w key... #13
# 14 is a replacement lock.
Adjust part 17.( Usually more downward) The latch action usually just pushes the catch upward.
It's angled and adjustible. I also had to take a dremel to the inside and shave a little to make the catch action better.
The second thing is to look hard at the hinge on the floorboard wall. They tend to get sticky/ rusted, etc. But you can loosen the screws- 3- and shift that cover a bit to give you a little more play for the latch.
"My door keeps opening when i'm driving.........Any fixes?"
....Slow down ya mad man! lol!
-shanon
fusebox door
What I have had luck with is to remove the panel next to the fusebox door under the steering wheel, then you cram your head in by the accelerator pedal and you can see exactly where and how the latch and catch meet and adjust it accordingly
Ernest
Seeing this picture reminds me that this happened to me years ago. The pin will probably fall out again. I think I put a drop of glue on the hole the pin goes into.
My quick temporay fix has been to wedge a leather watch strap along the right side. It holds up pretty well, until I go over a bad bump in the road.
similar situation
What I've done when fixing 2002 odometers, where the tenths wheel slips on the shaft (and you shaft slip issue is similar) is remove the shaft and ding it lightly between two ball pein hammers. This puts a small deformation on the shaft which makes for an interference fit in the shaft hole, then it won't slide out. Some like a drop of superglue to hold the shaft in place.
Now, before anyone takes the shaft out of their odometer, let me warn you that you'll need a lot of patience and care to reassemble the wheels on the shaft. But you can reset your mileage to zero all the way across and then you can time your oil changes and tuneups a little better.
For any that might question the legality of this, it's probably not, and I'm not licensed by anyone to do any such thing. But at the time I was buying and selling 20- or 30-year old cars whose odometers didn't work when I got 'em. I always notified the buyer, and checked off the box on the title form to the effect that the indicated mileage was not correct. The actual mileage neither I nor the seller had any way to know. We frequently didn't have receipts with indicated mileage to tell us what might be correct. No foul as far as I was concerned. No one buys old cars in the under $3,000 range expecting things to be in as-new condition.
