garymartin
garymartin
Surrey, England
HELP PLEASE!!!!!!!!!!
building E9 race car, sent E12/M535 front struts to be converted to coilovers, then realised not same camber angle, so sent second E9 set, now the company I sent them too have mixed them up, not sure correct set to convert, they have diferent size stub axles, can someone please tell me the correct stub axle size
thanks
gary
based in UK. just need stub axle size PLEASE
thanks
Gary
shanon
NorCal
Did you try calling Ireland Engineering?
They build E9 coilovers.
HTH
-s
dang
Administrator
Rocklin, CA
Not sure this helps, but I just worked on my struts and had a pair from my '69 CS and a pair that I ended up putting on the car that came off of an E12. The E12 strut mounts on the bottom (the 3 mounting holes) are a larger pattern than the E9 and require a different link arm for the steering linkage. They may be able to look at the struts from the bottom and pair up the mounting pattern sizes.
Dan
garymartin
Surrey, England
E12 front strut/ fit e9
Me again, got myself in a mess with a set of e12 and e9 struts, can you fit either to e9 please, and can anyone recomend best place for polybushes for e9, building E9 race car, have early Alpina engine to fit
based in London
thanks
gary
