Gas Filler door removal
Laldog
Boston, MA
What's the procedure for removing the gas filler door?
Any tips and hints would be appreciated.
Tundra
South
Taking it off is really not all that difficult. It's putting it back that can be frustrating as you can damage/scratch the body if you are not careful. To take off, look at the rubber covering the filler neck of the gas tank inside the trunk. There should be two holes. Through these holes you should be able to access the 3 bolts that are securing the door to the car. If I recall correctly you will need a 7mm socket. Be careful not to loose these bolts, they are small.
