Hello Hal and Mike, I didn't know you were talking about my car until I stumbled onto this. I finished this install of the Getrag 265/6 last August. Been driving ever since. The shifter platform I made from pieces of the four platforms the man gave me when I bought the transmission last May. I never liked how it worked out and when I saw Hal's platform, I dived on it. Took the old platform out and tried to fit the new one in. It was too low and seemed to be off center of the tunnel to the rear about 3/4 of a inch.
Called Hal and discussed situation. Decided to modify platform so that the mounting isolators would point downward instead of upward. It lifted the platform towards the tunnel and as a side note centered the shifter hole to fit the tunnel hole exactly. My question to you is; Is the shifter rod supposed to point directly into the shifter coupling like a driveshaft has to point directly into the transmission or is there a angle that is to be expected. The angle I speak of is from the shifter rod pin at the shifter to the shifter coupling? I am looking at the shifter rod like a drive shaft with U-joints at either end.
Hal's shifter bracket is a marvel of simplicity, it is strong and universal. A big improvement over what I had. It snick's into gear now. You can't hear it, you feel it.
I believe the tunnel height is different on a E3 versus a E9 but I don't one to compare to. Will add some photo's tomorrow.
Thank you.
Larry Louton
