Getrag Transmission Fun.
Still on the topic of synchros and dog clutches, I found this good photo. I think this is slightly different fromthe 265 synchro, but it gets the point across.
Here we have the shifter on the left, and a gear on the right. Remember the shifter has two parts, the outer part with the circumferential groove engages the shifting fork, the inner part is splined to the output shaft. You can see the spline in the photo. The outer part slides on the inner part along a set of teeth that go all the way around the circumference of the inner part (sort of a large diameter spline). This is the "dog clutch".
The gear has a set of teeth that have the same diameter and pitch as the inner part of the shifter. You can see these onthe left side of the right hand gear.
The bronze synchro ring sits between the shifter and the gear. It has a conical inside surface that engages that conical surface of the gear, which you can see between the ring and the gear, and a set of teeth that also match the outer spline teeth (the "dogs") on the inner part of the shifter. When the outer part of the shifter slides to the right in this photo, it will first engage the teeth on the synchro ring, causing it to move slightly against the conical section of the gear. This will cause the gear to change its rotational speed to match the shifter. The shifter continues to slide right until the teeth on the outside of the shifter engage the dog teeth on the gear. At that point the gear is locked to the inner part of the shifter by the outer part of the shifter, and since the inner part of the shifter is splined to the shaft, the gear is now locked to the shaft.
That is a useful analysis and picture Scott. Two intriguing questions remain in terms of the details, 1) how does the non-linear motion (H pattern) of the shift lever gets translated into a linear and gradual displacement of what you call shifter in the picture; 2) the gear helicoidal teeth on the right, do they engage/disengage when shifting, or are they always engaged but they get attached/detached from the shaft and that is all?
When I fail a shift and hear the dreaded gear impact noise, I always imagine gear teeth not meshing, but it is perhaps dog clutch teeth making that noise.
The helical gears are always engaged. The selectable gears (1 through 5) are mounted to the output shaft on roller bearings. So, they ordinarily just spin on the shaft. They are always engaged with their counterpart gears on the lay-shaft, and so, if the input shaft is spinning, each of the selectable gears is spinning at a speed related to the gear ratio.
To select a gear, you move the corresponding shift fork and that moves the shifter to engage the dog clutch as I described above. The dog clutch locks the selected gear to the output shaft completing the torque flow from input shaft to the lay shaft, to the selected gear, to the shifter and then to the output shaft.
The crunching sound you hear when you miss a shift is the dog teeth grinding together.
Here is a simplified diagram of the shifters and gears going from neutral to one gear and then the other.
The shift forks get moved by the shift rods, which have small tabs on the ends that engage a mating tab on the main shift lever (the gearshift part the driver moves). As the gear lever is moved right to left, it engages one of the three shift rods. Moving the gear lever forward or backward then causes the fork attached to that selected rod to move forward or aft to move the corresponding shift fork. Here is a simple diagram of this part.
That is what I suspected for practical reasons. Helical gears are coupled at the factory, no play, no need to engage ever again.
That makes the role of the roller bearings hugely important, if they ever start developing friction then it is as if you are driving on two different gears at the same time... Imagine you are in 5th gear but the second gear roller has 50% friction, it effectively causes your own engine to operate as a brake towards the driveshaft, as if you kind of downshifted. It would be noisy and develop some heat I guess.
I assume a transmission rebuild starts with replacing all roller bearings...
Now I get the shift rods and why the H pattern.
Lateral motion selects which rod, back and forth determines towards which gear it moves.
Yes, For a 5 speed there are actually 4 shift rods. One for reverse, one for 5th, and two for the 1-2-3-4 H-pattern.
The 265/6 5 speed has a sort of tenedor del diablo shift pattern, with reverse far left and forward, first left and forward, 2nd left and back, 3rd left and forward, 4th left and back, and 5th far right and forward.
265/6
265/5 (CR)
Fascinating, here is an open transaxle for a FWD car. Still 5-speed. The straight cut gears on the left are presumably reverse, and then 1st through 5th in sequence to the right. The notable part is that the input and output face the front of the car so presumably the shafts are one inside the other with a bearing or more in between...
Interesting.. I am wondering if the input shaft goes through the output shaft, making the input gear the one on the far right.
I'm sure this has been covered before, but I thought it would be useful to compare the gear ratios in the typical E9 transmissions:
Notably, the ratios of the 262 and 265/6 are very similar (within about 6% of one another), with the exception of the overdrive 5th. So, presumably the drivability of a 265/6 in an E9 should be pretty good, with a bit higher top end speed. In contrast, the CR trans has much lower ratios (6%, 15%, 22% and 25% respectively from 1st to 4th.
Been looking for a cut away side-view of the Getrag 262 4 speed. If anyone has one, please post it, and I'll color it like I did the 265.
In the meantime, here is an exploded view from the 262.
The basic architecture of the trans is close to the 265 above. You can easily identify the corresponding parts (just one fewer gear set).
To make sense of this, in the top stack of parts you can see the roller bearings for the gears, and the two piece (inner and outer) shifter. All of that strings onto the output shaft from the rear. The middle set is the input shaft, and a stack that fits onto the output shaft from the front. There is another shifter on that stack. I have numbered the gears (4th is straight through).
