Marc-M
Over the years I have tried to get a good finish with aluminium and failed.
So, the last time I needed my bits doing, I had them vapour blasted- they came out great, and the cost for the few bits was dammed $$$$$$$….
So, with a little help from the web and a few tips from youtube I tried a slightly different way and i hope it may help a few folk in the quest for a good finish...
I have a cheap blast cabinet that has never performed very well, but I decided to do the modifications that a few YouTube blogs have done.
The main thing was to make a metering valve – these are not cheap and cost as much as the cabinet – so I again found a youtuber who made one out of plumbing bits (commercial cast iron ones) so I made one that cost £18.00…
This makes a huge difference….
The trick is to blast the aluminium with normal hard sharp media at say 80 psi to get it clean.
This should give you a nice and clean finish but the surface is quite course matt and open (marks quite easy)
Then change the media for glass beads ( I used 100-200microns medium) – use new glass beads as they make the aluminium have a better satin shine BUT lower the pressure to 40 to 50 psi – this 2nd process only takes a few minutes and you can see it shine up in the cabinet as you work - even did the sump!!
I would say the 2nd process with the glass beads is not cleaning but peening …
Anyhow here are my results – I’m very happy with them and because the surface is closed – they are easy to keep clean and I think looks as good if not better than new – and it costs very little.
My Engine bay ... not so good
