execmalibu
- Messages
- 629
- Reaction score
- 2
I have (2) E9s that are Autos and my new 73 3.0CS ran terrible... It had hesitations and the idle was all over the place. So I just spent a couple of hours disassembling then checking, cleaning and lubing all the moving parts in my distributor. I found the advance both mechanical and vacuum were not working.
The springs looked OK so I left the mechanical advance in place.
Soaking the distributor in gasoline then spraying with carb cleaner got all of the old dried oil and other crap cleaned out and a few shots of WD40 got everything moving smoothly... Then I lubed with a special oil for guns (Breakfree) that does not dry out.
The vacuum advance was the dual type (advance/retard) and it was shot so I pulled an old Porsche 911 distributor off the shelf and stole the vacuum advance mechanism. The Porsche mechanism is the same as early E9s with only advance (no retard) and the tube is on the bottom. The Porsche mechanism might have a little more or less advance but it should be pretty close.
The car now runs great! No more hesitation and it chirps the tires in second gear. In truth I was very surprised at how well the car runs and drives with an Auto Trans not that much different then my 4 Speed E9...
Now that I know how well the E9s with an Auto can perform I am going to take a little time to check the distributor in my 1974 3.0CS also an Auto Trans. That car drives very smoothly but it is a complete DOG as far as acceleration. You step on the gas and by sometime tomorrow the car will get to 60 MPH!... It might also need a little distributor attention.
