Harmonic Balancer options
boonies
Cars aren't the problem, storage is...
US - Philadelphia suburbs
I am not happy with the engine idle, and have observed run-out (not yet measured) of the harmonic balancer. When I disassembled the engine it was without the center nut & washer (#5 & 6 in the diagram below). I doubt that the hub (#7 in the diagram below) is damaged.
There are a two options for used dampers near me, one is stated to be from a 1969-1981 M30, the other from a 1984 e24/633. The part numbers do not cross over. Any perspective on the interchangeability of m30 harmonic balancers?
What crank and crank hub are you using? There were two different bolt patterns. Early one only allowed one damper position; later symmetric used a locating nub. Belt drive pulley also should match.
Are you sure the crank nut is properly torqued? And if so, are the nuts holding the balancer to the hub properly torqued?
The center hub is original to the '72 M30 and it is torqued above the reading of the torque wrench which is ~275 ft. lbs. The pulley is a later two belt model, but bolt patterns matched up.
I will re-check the torque on the pulley bolts, I believe those were torqued to a general M8 specification ( from memory about 17 ft.lbs).
Interesting, it is the hub. I pulled the radiator and fan to get access to the balancer.
First checked the bolts and all were torqued as I remember. Then removed the bolts and pulled off the balancer and spun the engine with a remote start button and confirmed it is the hub.
I identified the hub as the problem by using a remote starter button while underneath the car. I first checked the assembly while intact and of course the balancer and pulley were clearly out of true. I then removed both the pulley and the balancer and the hub remained out of true with a noticeable wobble on the face of the hub.
I purchased a replacement and then removed my old one and found a different problem. The woodruff key was mangled. I sourced a new one from BMW (picture comparing new & old below) and carefully checked the machined pocket to ensure it was in good shape. I then partly assembled after carefully cleaning and oiling the front seal.
Once I determined that the original hub was running true I then completed the assembly, torquing the front hub nut and the balancer/pulley bolts. Engine is running again and I believe idling much more smoothly.
I know that I would never have assembled with a bad woodruff key, so my assumption is that the key moved during assembly, but I am not sure how that happened.
