Headers
Discussion in 'E3 General Discussion' started by Mot27cars, Feb 12, 2019.
  1. Mot27cars
    Mot27cars Member
    66
    13
    8
    Elkhart, IN
  2. Stevehose
    Stevehose Well-Known Member Site Donor $
    View My Showcase
    8,790
    1,183
    113
    New Orleans, LA
  3. Belgiumbarry
    Belgiumbarry Well-Known Member
    911
    434
    63
    Belgium
  4. Mot27cars
    Mot27cars Member
    66
    13
    8
    Elkhart, IN
  5. teahead
    teahead aka "Rob" Site Donor
    3,470
    602
    113
    Seattle, WA, USA
    I hear they require frame clearance and some tube banging.
  6. Bert Poliakoff
    Bert Poliakoff Active Member Site Donor
    928
    73
    28
    Scottsdale, AZ
    They are 2" headers IIRC and there is nothing to be gained from them, maybe even a power loss. Just eye candy at best.
  7. Bearmw
    Bearmw New Member
    14
    1
    3
    Western, MA
    I agree with Bert but would add that they might help with a higher compression 3.5.
  8. Bert Poliakoff
    928
    73
    28
    Scottsdale, AZ
    A 2" header is for a major balls to the wall motor. 1 1/2" is probably the max with 1 3/8" on a stock motor.
  9. Bearmw
    Bearmw New Member
    14
    1
    3
    Western, MA
    I was under the impression that the primaries are closer to 1.5" and the collector is about 2". Does that seem too big for a mid-level 3.5?
  10. Bert Poliakoff
    928
    73
    28
    Scottsdale, AZ
    If that is so, and you can live with it,you will possibly lose some low end torque.You probably will not gain anything from the headers. Other members will chime in but my understanding is, 1 3/8 is the number for a stock motor. If you go bigger you may start to lose low end torque. SF Don?/
  11. Gransin
    Gransin Well-Known Member Site Donor
    954
    451
    63
    Vasa, Finland
    Compared to the stahl headers, these ones are shorter before it reaches the collector, so I don't think you can compare the size of primaries based on just the diameter, you should also take lenght into the calculation.
    It's about the total volume, but I might be wrong:)
  12. Belgiumbarry
    911
    434
    63
    Belgium
    they are... if i may calculate that way : primaries 1.5 x 25.4 mm = 38.1 mm . ( outside 40 mm )
    collector 2 x 25.4 mm = 50.8 mm ( outside 50 mm )
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
