Headlight ground locations
Laldog
Boston, MA
Where specifically on the body do the headlight ground wires terminate??
Both drivers side head lights are strong and bright, but the passenger side low is very weak while the high beam is nonexistent. (The bulbs work with a direct 12v. connection)
I want to start with the grounds first.
Thanks in advance.
Grounds for the headlights are by the front turn signal lights. Open the headlight port and you should be able to see them. Probably 2 or 3 brown wires attached to the body with a screw. They are located on both sides.
Sven is spot on....electrical guru....an overlooked ground being behind the front turn signal lamp assembly, and as he says, right and left sides.
