nobrakese28
- Messages
- 232
- Reaction score
- 12
After spending all day under, above , and in my CS I have the auto transmission out as well as the pedal box. The starter probably took the longest to remove.
I was originally planning in attempting to add the clutch pedal, but the auto box did not have "clutch spring pivot point". So I pulled the entire pedal box.
When I placed the pedal boxes next to each other I noticed the manual pedal box did nit have the same mating points for the steering column.....
I come to realize the manual pedal box I have is out of a car with telescoping steering.
I found a few boxes on ebay that will work. On a non-telescoping steering car, what does the clutch spring assembly pivot on?
Can some one send me some photos of there clutch pedal? I would really appreciate it!
My options:
1) Buy correct box.
2) See if Ben at 2002AD will trade me boxes
3) Some how make my auto box work by mixing and matching, the pivot point is nothing more than a folded piece of sheet metal welded in place.
My options:
1) Buy correct box.
