Goose
Hello all.
Any brake experts here that can help me out with some ideas?
When I press the brake pedal, it does not brake; it goes to the floor, then it breaks a little.
Please read the entire story below since I tried a lot of things already.
Everything was working fine, the car was braking correctly until I noticed an unusual amount of brake dust on one of the rear wheels. Lifted the car and found out that the wheel was very stuck because of the pistons. So I ordered a rebuilt kit for both rear wheels and fixed that issue. At the time of bleeding the system, I noticed that no brake fluid was coming out of one of the rear calipers. That's when I realized that the two rubber hoses on the back have not been replaced with metal ones (the front ones are metal already). So I replaced the hoses and brake fluid come out from the calipers.
Now this is when my current problem started. From here, I could not get the brakes to work. After several bleedings, including using a pressure bleeder. I can't get the brakes to work. They go all the way out to the floor and then it breaks a little.
Assuming that was a vacuum leak, I first replaced the return valve. Nothing happened, same problem.
Thinking that there was a leak on the booster, I sent it to be rebuilt. installed and the same problem.
Then I bought a new master cylinder. Same problem.
BTW, no fluid leaks anywhere in the brake system
I'm out of ideas and options. Here are some interesting facts:
-When I press the brake pedal, the fluid in the reservoir goes down noticeably. When I release the brake, it goes up again. Could this be air?
-When I have the pressure bleeder connected to the reservoir, with pressure, the wheels do not rotate, it is like if they have brake pressure applied without pressing the pedal. If I release the pressure on the bleeder and press the brake pedal with the car ignition off, I can rotate the wheels with my hand, there is no pressure on the brakes stopping the wheels.
My next thing to check is to remove all the seals and pistons on the front brakes, but I don't know if that is going to do anything.
Any ideas or recommendations will be appreciated.
best.
best.
| ReplyForward |
