A small project just got ugly...
I purchased the pertronics electronic ignition for my bavaria to convert over the points... sorry i'm posting in the e9 section just thought more may see it here.
The install was very easy, popped off the dist cap, pulled the points, condenser, screwed in the plate, the module, added the magnet collar, hooked of the wires, black to the coil, red to the ballast on the ignition side and away I thought I would go.
I went to start the car, had the hood still open and I noticed the entire distributor push up and out about and inch or so. I thought I was seeing things. I never pulled the full distributor when installing, nor did I loosen. I went to push it back down and tighten and noticed the rotor will not freely spin... so I can't line it up to the center point. It rotates about half the way and then back again. It won't allow a full rotation. I got to the point that I pulled the full distributor and still can't freely rotate the rotor or the gear shaft. It's like it's locked down to a half turn.
I'm very new at this stuff so I may be missing something obvious but at the moment, I'm stuck. Any idea what may have gone wrong.
Note, the car ran fine with the points prior to my swap and I didnt touch anything but what I described above.
Thanks for your help and wisdom.
