hi, it is my intention to replace the rubber profiles that are placed in the door opening, i understand that this is the frame of the door that runs from the roof, to the front A-pillar, then goes down passing close to the door hinges until the sill rocker panel, then back through the rocker panel, then up and ends there because there is no B-pillar in our coupes, that is weird !
to tell you the truth i will only replace the rubbers in an U shape, including:
-the vertical down line that runs close to the door hinges
-the horizontal line that runs paralell to the rocker panel
-the vertical (in fact it is aprox 60 degrees) that runs close to the door lock
the help that i am kindly requesting refers to the tips, and or difficulties that i might face while attempting this renovation
i am worried about which parts i do have to remove to have access and thus remove the carrier of the rubber profiles
i assume that you are able to identify that a rubber profile consists of a rubber lip and a carrier, the former seals the interior by being pressed against the door, the later fixes the rubber profile to the sheet metal lip of the door frame
once concealed that our target is to remove the carrier lets talk about what obstacles we will find in carrying out this task, or at least i will talk about the obstacles that i know hoping that you may help with the ones that i do not know
thank you for your help
