bavarian
- Messages
- 209
- Reaction score
- 49
Hey so I’m close to starting the b35 that I have swapped into my e12 and I have a few questions.
The e12 has an alternator and starter engine bay harness , the e34 harness has starter wires , I was going to use the stock e12 engine bay harness and wraps the e34 starter wires , here we had double starter wires I’m thinking go e12.
The e34 has a clearly marked red set of wires where the positive is supposed to go to maybe to power the ecu, can I wire the e12 coil pack positive to the ecu power which should give power to the coil pack , I already forgot how it goes
Basically I have fuel pressure at the rail , I can get the starter to spin I have all sensors and everything plugged up, but I’m looking for what wire is needed to power the ecu , I just want to hear the motor run then I also would like to find the rpm signal to connect the b35 revs to the cluster , would the green distributor wire from the e12 get me that and would I connect that to the coil pack to get the rev?
