Hood Torsion Bar Adjustment
E3_UK
Since having the car painted I have noticed that the hood isn't receiving sufficient force from the torsion bar and tends to drop. What is the process for increasing the preload ?. Nothing is broken, I'm just assuming the guys at the shop didn't reinstall it exactly as it was when removed.
The thing isn't adjustable. If the shop took the torsion bar assembly apart (and I can't imagine why they would, unless they wanted to paint each component separately), they could have messed up installing the two blocks that anchor the fixed end of each torsion spring. But more likely, the springs have just lost their tension and a replacement is needed.
Do the torsion bars have almost enough force to hold the hood, or not nearly enough? In other words, is it dramatically weaker than it was pre-paint?
Question: are replacement torsion bar assemblies still available?
Here are some helpful hints curtesy German forum !
Basically you should do this with two people, otherwise you will scratch the whole hood.
Loosely mount the bearing block, torsion bars, and tube with struts, but do not yet install the end stop. Insert the complete hood strut assembly and tighten the screws. Then, by slightly twisting the struts, secure the end stop. This will create a slight preload when the hood is open. Finally, attach the struts to the fender.
You must mount the hood strut to the hood without any tension, as shown in the first two pictures. Then, you must extend the strut away from the hood, approximately at a right angle, and position and tighten the stop bracket. (From GR)
The torsion bar was simply disconnected from the hood. It feels like it almost has the same strength as before, maybe it has just loosened a bit from being removed. I thought perhaps that the torsion springs could somehow unwind, requiring re-setting.
Well yes. But the pot metal parts that bavbob refers to in post # 4 are secured with the same bolts that mount the whole assembly to the hood. And those parts are what anchor the fixed ends of the springs. So conceivably, one could have shifted outward when the spring assembly was loose, allowing that spring to lose its pre-load. If that were to happen, one arm would require less torque to rotate it than the other. But I don't think there is a way for the spring to loosen just a bit; it would either move 180° or not at all. And given the amount of preload on the springs, the clunk would be pretty audible if one came adrift.
If I had removed it myself I would have been aware of it losing preload I suppose but the shop removed and refitted it and they aren't necessarily fully conversant with the mechanism. Should I therefore unbolt one side and rotate the block to increase the preload ?.
You can try. But that presumes that the fixed end of the spring did slip out of its slot. If that happened, one arm would require less torque to rotate it than the other - is that the case?
You should also be aware that those torsion bars take a LOT of torque to rotate. Treat these hood torsion bar assemblies like a rat trap designed to kill a human-sized creature. If it snaps on some part of your body, it's going to cause injury.
It doesn't seem like one side has lost its preload. The hood does stay up, but it slammed down when the engine was idling roughly after a cold start and it has never done that before the body shop worked on it so I am assuming that there has either been a loss of preload due to it having been removed somehow. Thanks for the heads up on the dangers though, I think I might just leave it and use another prop for safety to avoid being decapitated by the hood.
If the center part of the mounting brackets are worn, twisted or damaged then it may cause this problem I think. When I replaced the hood on my car during the restoration I got a used hood with the brackets still attached but not the bar. There where obvious signs of wear on them, so naturally I replaced them with new ones.
