Horn Relay Wiring
TG-2002-320i-328ci
Tucson, AZ
Anyone have a simple diagram of how to wire the horn relay? Mine knocked loose and lost a couple of connections. No horn. My "blue book" only references simple removal and install of the original type.
Thanks you
Terminal 30 gets large red wire from battery, 87 goes to the horn (green I think), 85 and 86 trigger the relay doesn’t matter which you use but one is ground, brown, and the other is the green or green/white.
Green/yellow to horn pin 87
Red to battery pin 30
Brown/yellow to horn button pin 85
Green/white to fuse 7 pin 86
