how does the handbrake wire attach?
here is a picture from my search - my wire was laying on the floor of the car (brown / blue) feeding from the drivers side harness that runs from front to back. the wiring diagram shows a cable end that is attached to the switch. my curiosity is where? i see it going under the spring switch
just goes to show you, it didn't stick in the memory. the good news is that i found a plastic piece 11 years ago, but i didn't remember about how to reattach the wire. looks like the spring end is pushed in and there is a hole in the pin for the wire to be inserted. so it just goes to show you, its hard to teach an old dog a new trick ... and if you do, its hard to teach him to remember the trick. maybe this time i will remember now that i've had my nose rubbed in it. appreciate the reminder Erik!
google is actually a better way to search e9coupe for detailed searches. when you get to looking for things with only 3 letters, our search doesn't work - like air or a/c.
Actually it isn’t. There is a hole in the post that the wire goes into and is held in place by spring. You have to push the spring in to expose the hole
