In the proces to clean up the underside of my e9 I have taken out my propellor shaft.
It came out easy enough, it had a few tough nuts but lengthening my spanner with a 1 meter (3 foot) tube did the job.
I have a small lift and the shaft isn't that heavy, about 15 kg or so.
The rubber disc, the center bearing and the cross joint are all in good shape; they look good and feel smooth. But after cleaning the the whole thing, I noticed it's a bit rusty underneath the layers of wax and under body coat. I'd like to get it nice and fresh again.
My questions
1. How can the cross joints be seprated into individual parts? I know that they are supposed to be removable by removing the caps, pushing them to one side, releasing the other side. However to remove the cap, it looks like I have to grind out the 8 little folded tabs (see picture). How ever will i be able to reinstall the caps then later? (I see W&N supplies springs with, but there does not seem to be an groove to locate them)
2. Will it be a problem if I dismantle & get all parts zinc plated? Would perhaps the seating surfaces of the cross bearings be compromized by the plating process?
My questions
