decoupe
(deceased)
Title says it all.
Symptoms are fluctuating vacuum reading at idle and deceleration (all the foot off throttle conditions) through a MAP sensor that provides info to the ECU. Result is a crappy rough idle at 1250 that stalls if I try to go lower and frequent stalling when foot of gas decelerating to a stop. No effect on accelerating and wide open throttle.
Background. Running an after market standalone engine management system (SDS, not MS) that ran last years L Jet based 3.5l flawlessly (other than a persistent ear piercing throttle plate whistle associated with that series of throttle body). Great setup other than the whistle.
Current setup. No changes to the 3.5l engine. I refurbished a '89 e32 B35 intake, throttle body, fuel rail, new 30lb bosch injectors, Tii brake booster plus the existing SDS engine management with no changes - just plugged it all in and it fired right up. Just idles poorly.
To date I have confirmed the spark, timing, fuel pressure, MAP sensor (swapped in a new one to check) checked all of the electrical and hose connections and sprayed liberal amounts of engine starter at likely areas for vacuum leaks. No luck. I've been told that propane is a better method of finding vacuum leaks and will try that tomorrow.
The symptoms just scream vacuum leak to me. My suspicions are that the brake booster hose or one way check valve are at fault but no amount of wiggling the hose shows anything wrong. Other possible culprits? Any of the vacuum ports on the b35 intake I guess but the vacuum line to the fuel regulator and to the MAP sensor are new, the valve cover vent hose to the intake is hose clamped and new rubber (had to home build this).
The whole thing is a bit if a hybrid - no start valve assembly, there is a fast idle bypass relay that closes at 73c - engine warm up does not seem to be seriously effected while the relay is open. That fact and that when using lots of throttle shows no issues leads me to think the leak is small but persistent at idle.
As I said earlier this started, idles and ran flawlessly last year with an L Jet setup. Only the brake booster and b35 intake (fuel rail, injectors etc etc etc) were changed.
Anything come to mind - I'd appreciate hearing.
Doug
Doug
