Idle speed issues
Laldog
Boston, MA
Trying to fine tune my weber carbs. Popping through thru the carbs upon acceleration led me to believe that they were running too lean.
I didn't touch the idle set screw, but as I increased the mixture (more rich) the idle speed picked up considerably, close to 3000.
I checked for linkage hangups (none that I could see), the engine was warm. Punching the accelerator pedal did nothing to bring it down (or clear any linkage issues).
I dialed back the idle set screw to make sure that wasn't the issue, and though it did decrease the idle speed a bit, it came no where close to where it should be. (The set screw is no longer in contact with the stop)
My question is this:
How do I get the idle down to where it should be?
(The carbs are supplied by an electric fuel pump)
Thanks in advance.
what about your individual throttle butterfly screws on each carb - where are they set?
