Can I temporarily swap out the coil in my '74 CS(i) with one from a '89 Saab Turbo (Bosch, of course) to rule out a coil problem (trying to eliminate possible causes of seriously poor running..it could be a D-jet problem.) The coil in my coupe doesn't have a ballast resistor ('74s use a resistance wire in place of the resistor, one of many things that make '74s so unique) and I don't know if it's "internally ballasted" or not. I figure a short-term test wouldn't hurt, or am I nuts?
Not so sure you can judge a coil by it's looks. I could be wrong but your '89 SAAB probably uses a transistorized ignition module, versus the kettering ignition points-triggered system used in the majority of E9s. (Of course, some E9s employed transistorized ignitions, but it "seems" that they were in the minority.) Sight unseen, I would guess that the SAAB coil's resistance is lower than the 3 ohms HBChris mentioned. I don't pretend to know the original equipment specs for a 74 csi, but 3 ohms seems more in line with the replacement blue coil (often , but not always, internally resisted) rather than the originally installed black coil, which
did require an external ballast resistor.
Curiously, the undated so-called late model owner's manual found elsewhere on this site indicates "9" ohms, although it probably should read "0.9" or ~1ohm.
Although it probably offered no significant advantage, what used to be labeled the red coil (with more windings), generally required a 1.8 ohm ballast resistor. ("Generally," because for every rule there seems to be an exception.)
https://e9coupe.com/forum/threads/ignition-coil.22231/
So, in answer to your question, the short-term test contemplated would "
probably" not cause any problems.
