Yesterday, I pulled the Bavaria into my driveway at home, shut it off and rotated the key to the far anticlockwise position so I could remove it. It wouldn't come out and the steering wheel was locked which shouldn't be locked unless the key is removed. The key wouldn't rotate to any other position either.
I tugged a little on the key, and it came out along with the lock cylinder and a bunch of little springs and metal cylinders...
After panicking I found that if I reinserted the barrel with the correct orientation, that the key would go in like normal and start the car. Also, if I rotated the key anticlockwise to the stop, I could remove the key and the steering would lock. With the rubber trim back in place it looked and worked like normal...
At least I can still drive the car.
In poking around, it looks like a real chore to remove the cylinder that is still in the column. I would think someone like Santa Monica Lock may be able to put things back together if they had all the pieces. Maybe it is easier to remove the upper column and send that along with the other pieces?
Is there an easier way to put this back together than the above?
Maybe even replace the whole upper column with another (I'm not too picky about matching keys)?
Ideas?
Ideas?
