my intention is to use the current wood, but replace the veneer.
I have absolutely no experience in doing this before and am only vaguely handy, I can chop, burn, cut down and generally take things apart with the best of them, but putting things back together is not my strong point !!!
I have taken off the lacquer using a heat gun and also the first layer of veneer using a Stanley knife blade (it was blown in most places anyway).
Someone else had taken the dash out as I am having a full body resto. so I just had the dash and door tops to work with.
Initially I had simply sanded all the wood and revarnished, but then saw some professional wood and it looked so good and mine so bad I decided to give it a proper go myself.
theory is simple...
- the door caps - just take off first layer of veneer, one coat of varnish so that the glue and veneer sticks, then sand, seal, and lacquer. I am at the coat of varnish stage...
- the dash..different..first off needed to take apart, this is a pig because all the old screws are rusted/stuck fast/broken etc. I ended up cutting out some of the screws along the underside of the dash so will need new fixing points if I use the same base - this is still under consideration and if I do make a new one it will be out of marine ply - then the wooden grab rail is also held in place by two end screws, one had broken but I managed to get one out, then gently prise the thing apart.
The wooden inserts in the vinyl are glued in place, so gently prise them out.
it is now apart and I am gluing the substrate /varnishing stage.
Question....what do people think of the speaker delete ? it would be so much easier to reveneer without the speaker and in all honesty, I am not going to put in a sound system, I intend to use a wireless speaker hooked upto my phone if I really get desperate. Would covering it over detract from the car do you think ?
more pics to follow at the weekend.
