Interesting:
(... )A maximum exposure temperature / time of 90 ° C / 40 min. Must not be exceeded during painting work
will. Powder coatings with higher temperatures and exposure times are not permitted. On
Due to the heat input and / or the wetting with paint, it is recommended to replace existing valves after the painting work (...)
more about can be read here:
www.rtsauto.com
I was not a fan of powder coating anyhow. The problem is most of wheel shops is still and ONLY doing powder coating. They claiming 180C (~300F) is used by wheel manufacturers so it is safe.
Good to know even if you disagree to that report
Is powdercoating bad for rims? Yes, and illegal in Germany. So is using heat to bend them back. | RTS - Your Total BMW Enthusiast
Most powdercoating establishments, including rim repair ‘professionals’ powdercoat and then bake rims between 300F and 400F for around 15-20 minutes. What if I told you that baking aluminum alloy wheels at 300-400f will weaken them permanently? Aluminum is annealed when new, which for the laymen...
www.rtsauto.com
