I had some time over the weekend to start working on the Motronic conversion again.  Went to the junk yard and pulled a wire harness out of a 735i.  I know in the conversion not all of the wires in the harness are used so I started pulling out the ones I know would not be needed and, while I was at it, I ohmed out all of the connectors.  My question is what to do with the connections/wires that will not be used; just pull them from the harness or do I need to do something else?  To be more specific here are the ones I’m interested (the names are right off the wiring diagram):
Evaporative purge solenoid
Engine speed output (to instrument cluster)
Diagnostic TX & RX (are these RS232? They are not a twisted pair if they are)
Check engine light
Programming voltage
Compressor on input (maybe I should use this one)
ASC & Anti theft, Park Neutral (I could see this one causing problems)
Torque converter
There is a pair for the O2 sensor as well but I haven’t decided yet if I’m going to add an 02 sensor.
As always, any and all help is appreciated!
Scott
Check engine light
Programming voltage
Torque converter
Scott
