Is there actually a repair set for the brake force distributor?
eriknetherlands
Netherlands, Eindhoven area
I have my brake force distributor out of the car, dismantled, refreshed etc. Normally i'd take the opportunity to replace the 2 black rubber seals on the piston, but RealOEM does not provide a number for the kit, identified on the parts drawing as RS 8; RS for Reparatur Satz #8.
are these seals actually available?
take it apart and size the seal -then you can match it at the parts store
ive done that on many occasions
the o-ring is no problem, just remember to ask for EPDM
the second seal is not that easy, i would not touch it, you can break it and there is not an easy way to replace it, at least i know of no source
I have always feared to fiddle with this. Exactly how can you test "in-vivo" that the thing is working the way it is supposed to?
As no repair set is appearently available, i'll just keep in mind the testing procedure (thanks Barry) and if it fails I can always try to use the hint of DeQuincey to replace the generic O-ring (choosing EPDM). So assembled the whole thing and put it away for later install.
deQ, is this thing nothing more than a resistor in series? Are there two ways it can fail, always open or always closed? Sorry, just turned 60, asking a lot of questions about a lot of things these days.
this diagram shows the working of the brake pressure reducer.
B is the pressure you make with the pedal , the same as in the front calipers
A is the reduced pressure in the rear calipers
the harder you brake the more weight transfer to the front wheels , so they can take more brake pressure ( more tire friction ) and the rears less and less
in fact a pre historic ABS system.... so the rear wheels don't lock first and the car would go sideways.
nice demonstration of rear wheel locking on purpose ... to turn a car :)
The grey stick next the gear stick is the same as the brake pedal but only acting on the rear wheels and without pressure reducer ....
Quite interesting, I thought this was the way it worked, always a gradient between the front and rear pressure, I did not predict the gradient changes with pressure, thought constant.. Thanks!
