Howdy folks, I'm posting for a friend over on BMW2002FAQ. Hope y'all can help.
Ed
www.bmw2002faq.com
He's asking:
Mike S suggested I try here -
Anyone have a photo of how the jack and lug wrench store in a 3/73 Bavaria? I've tried just about every orientation I can think of, and the hole in the jack just doesn't line up with the studs at the rear. Also, should there be an adapter ring under the clamping plate that retains the wheel? We have two plates, but no ring. RealOEM diagrams indicate there might be one, but it gives no description or part number. The clamping plates (there are two) seem to be notched to accommodate the lug wrench, but, when sandwiched and on the center stud, there are not enough threads for the nut. And the plates' notches do not match up to the center-hub lip. This is an all-original, 1 owner Ceylon automatic car with less than 25K on it. We're trying to keep it as complete and original as possible - the original spare has never been on the ground. The car has been converted for use with hand controls, which we are documenting, removing, and saving. It's a time capsule.
Thanks,
David
Ed
<OT> Bavaria question
Mike S suggested I try here - Anyone have a photo of how the jack and lug wrench store in a 3/73 Bavaria? I've tried just about every orientation I can think of, and the hole in the jack just doesn't line up with the studs at the rear. Also, should there be an adapter ring under the clamping plat...
www.bmw2002faq.com
He's asking:
Thanks,
David
