KHM Carpet set
I went with Dynamat first, then layers of felt cut to fit the various depressions in the foot wells then more felt to make a smoother surface, all glued together and firmly held down for a day or so. For the transmission tunnel and the sills to reduce the bumps from the wiring loom etc I used stiff card from the trim shop, cut to fit and glued again to the felt. Finally plenty of glue on the back of the carpet itself ( I needed to trace a wire for the antenna later and it came apart and went back together fine) I found that the felt could be pulled apart to give half thickness where needed, and the card gave much smoother lines.
that is a work of love, aka a work of art
D388CB9D-6E6A-4ED9-BDB5-4EBA5437003A.jpeg 9C949215-59E2-45F6-8991-529661F5B4D6.jpeg B55F9E2A-6302-46DA-B2C2-4CE1AD43733F.jpegD2D0E0AE-8011-4345-BD7C-7826DA3A17D0.jpeg 0F3AA324-4C65-47FF-8344-55DF15BE0365.jpeg 2526DE19-5352-4EDB-A88C-044914D92BC6.jpeg
Great job,
On my prevoius coupe I cleaned the floors, undercoat spray, Dynamat layer, Dyanamt foam/rubber padding. I plan to do the same again.
D37B37F7-D2FE-4FAA-AF99-896AD067AF42.jpeg Question? Did the heel pad differ from year to year? I wrote to KHM about it, he said that he copied it from his wifes car and looked different from the picture I sent him. He likes to know in order to do the correct pads. Thanks
