aearch
pleasant hill , ca
Where do these parts go
The flat long part appears to be the rubber seal that's attached to the rear lip of the sunroof panel (hidden from view).
I think the small steel piece mounts to the window mechanism. It is where the rubber stop stops against.
Seal trim
Still not sure where this trim goes
looks like around the rear window from the profile
i have all the sunroof seals
THERE ARE TWO OF THEM
it has a curved end with a slight radius
Pretty sure it is the 3rd rubber seal that sits atop of the rear sunroof panel lip. It's totally concealed from view once installed. It acts more of a cushion than a seal. This pic is from a 2002 panel, but the application is the same.
