m30 oil pump rotor and gear dimensions
Anaphe
Hi Guys,
Working on a Schnitzer oil pump, hoping that the gerotor was borrowed from a period BMW. Does anyone have the dimensions or a spare pump on the bench they would be willing to measure up?
Thank you!
Anthony
I am assembling an engine with the same pump.......I can check the measurments for you today......Alex
The pump rotors for the scavenge are from a BMW M10 engine, the rotor for the pressure there are two types, one is 22mm which is from a normal BMW M30 engine, the wider one that you have does not exist on any series BMW so far as I know. Hope that helps......alex.
Hi Alex, I came to the same solution.
Not sure where to go next. I am sure the rotor is corresponds to an OEM piece, but no way of knowing.
Might have to look at getting it manufactured.
AK
