Hi all!
I transplanted a M30b34 Ser#5550551 into a 1973 e9 CSA #2232522 and have not been able to get it to idle.
It starts on the cold start valve OK, then will only run above 1300rpm with throttle partially open.
It will only run briefly on the idle circuit between 750 and 900 rpm when warm and if the connector to the temperature sensor #13621709966 is removed.
The management system is the original Bosch Motronic Basic DME 0 261 200 002 with no oxygen sensor or pollution gear attached.
The following is a list of actions I have done to attempt to rectify this issue and I would welcome any suggestions that you may have to solve this problem.
Many thanks
Ken
BMW m30b34 Ser.# 5550551 Type Code: 5332
ISSUE: Engine won’t idle and hard to start.
Items tested or replaced.
1. DME tested OK
2. AFM rebuilt
3. Temperature Sensor. Pt#13621709966 new
4. Temperature/Time Switch. Pt#113621274630 new
5. Cold Start valve: Tested OK
6. Wiring Harness connections to DME: Continuity tested OK
7. Throttle Clearance: Adjusted to spec
8. Fuel Pressure Regulator: Tested OK
9. Position and Speed Sensors: Tested OK
10. Hoses checked for vacuum leaks. None detected
11. Spark Plugs cleaned. Evidence of overfuelling (black)
Many thanks
Ken
1. DME tested OK
2. AFM rebuilt
