Post #10Aren’t the nuts to be on the flangers side?
Hi Gentlemen
I’m preparing to swap my 265 for a better 265 and discovered my Guibo going bad.
It’s a e34 m5 guibo
Probably under 5000 miles on it, maybe more
Looking up numbers I found a few,
26112226527 I want a good one ... Jurid? The best per past posts.
Help me out I don’t want to buy junk parts
its installed backwards arrow goes to front
Post #10
Using a long nosed manual driveshaft with a m5 guibo manual Install can result in a gap that gives a guibo a wavy distorted appearance. That wave is caused by the difference in thickness of a stock guibo (45mm) and an m5 guibo (35mm)
Inserting factory bmw head bolt washers into the gap solves the problem.
Also- instructions are explicit and nobody seems to read them.... never tighten the bolts! The nuts get tightened.
This preloads the guibo. Not good.
And finally - guibos have arrows for a reason. Put them on backwards and they crack and then come apart.
I still have a few questions if possible:Catalog picture 26/03 - BMW 2,5 CS - 3,0 CSL (E9) - Propeller shaft | Wallothesch
www.wallothnesch.com
1- if I install 35mm M5 guibo should I still keep the parts ## 2,3,4,5,6,7,8 on a diagram installed or m5 centering bushing 26 11 7 526 611 should be installed or nothing?
2- which bolt length needed 60, 62 or 70mm?
3- what's the ring #11 on a diagram for? And what's a bolt length used in original setup? (45 for guibo+ 10 for nut+ 12 for flange+ 2 for washer+ X for #2 ring= ???)
4- where exactly head bolts washers should be installed? Some pictures would be nice.
Thanks a lot!
