Sven --
I don't use Megasquirt, but I do have a fully programmable ECU. Here are two timing tables I've been using. The first one is one I modified from a vette motor with aluminum heads. It is a little more conservative and is much smoother. It feels like it provides more torque too. This is what I'm running right now. You can probably bump up the upper values by a couple of points, but I would leave it as is and just work your fuel tables around it.
The second one is one I built up and ran for the past year. It is pretty raw and has great power and throttle response, but it is jerky at low/mid rpms. I think this table gives better power in the mid-range, but at the expense of driveability. I ran both with 91 octane and got no pinging.
Here's the first:
Here's the second:
Hope this helps.
Here's the first:
Here's the second:
Hope this helps.
