- Messages
- 57
- Reaction score
- 3
Has anyone done a Motronic 1.3 upgrade? This is stretching my normal range, but with the best will and perhaps a little direction from this community, I'm hopeful for a happy ending.
I'm converting from Motronic 1.0 on a 1989 E24 motor with L-Jet intake. This weekend I stripped the ECU, harness and associated bits from a 1989 535i.
My specific questions are:
1) Is the harness long enough. The 535 ecu was in the engine bay. Mine's in the glove box. Looked like it would reach
2) Do I need anything past the driver side diagnostic port/engine harness connectors? Post connections, the harness looked like it went into the driver side fuse/relay box and forward toward the ABS module, and ultimately into the radiator. I'm assuming this is all for modern paraphanelia that doesn't apply to an E9.
3) There were two connectors under the intake, next to the starter, that I couldn't ID. One may be for the evaporative purge valve (per Bentley). The other was a collar type connector that led to another harness, possibly heading off to the trans. Will I be using these, and do I need to go back and get what they were attached to?
4) Wondering if I missed anything. I grabbed the 179 ECU, harness, ICV, TPS, coil, temp sensors, rpm/crank reference sensor & harness, toothed timing wheel, cylinder 6 firing sensor. I already have airbox, 027 AFM, throttle body, correct injectors, relays, etc. in my Motronic 1.0 setup.
I need to head back to the junk yard and grab anything else I need this Sunday, hopefully from the same car.
I would be grateful for any advice.
Garrett
Garrett
