Nd Help with Overrider-Bumper fit
jmackro
San Juan Capistrano, Ca.
I am nearing the completion of the metalwork on my 2800 CS. This is a car that I have owned for 19 years, and was together and on the road up until this summer. When I got the paint off of it, there was evidence of one or more front end collisions, so the bumper assembly has no doubt been "tweaked".
The specific problem I am trying to solve is the large (about 1/4") vertical gaps between the overrider and bumper. I have a gap at both the top and bottom of the overrider-bumper. Yes, we are doing the trial fit with the thick rubber pad mounted to the front of the bumper, and the "U" shaped channels wrapped around the overrider edges where they come in contact with the bumper. No, the overriders have not gotten swapped L-R or up-down. I honestly can't recall how large this gap was before disassembling the car - I would think I would have noticed if it were this large.
Either the "C" -shaped cross section of the bumper has been flattened, or the corresponding section of the overriders have been expanded (or both!). If the overriders were impacted from the front, they would probably open up. Dunno what might cause the bumper to be flattened, but over 38 years, anything is possible.
My questions for the group are:
- If my overrider measures 5-1/2" (140mm) from top to bottom at its midline (see 3rd photo below), is that greater than stock?
- If my outer bumper measures 4-1.4" (108mm) from top to bottom behind the overrider, is that smaller than stock.
- Note that in the fourth photo below, where I compare my two front overriders, one is more opened up than the other. Is this the normal manufacturing tolerance, or has one definitely become bent?
- I know that a rubber "U" channel wraps around the overrider, and hides some of this gap. But, are big gaps typical in this area?
The final photo will give you an idea of what the car looks like at present. We are about to begin painting, and then it's reassembly time.
Thanks!
From the profile of the front bumper as shown, it appears that you may have mounted the bumper upside down thereby accounting for the overriders' not fitting correctly. The bottom of the bumper has a more pronounced curve than the top surface. Just my observation, I could be wrong.
The measurement is 5 1/4" on both of my new bumper overiders.
Bert
72 3.5 CSi
88 M6
Bert35csi:
Well, that 5-1/4" dimension tells me that my overriders are spread out. Mine measure about 5-1/2" from the outside edges of the metal. Again, I'm taking the dimension at the midline (in the horizontal plane when the overriders are mounted), as they taper in every which direction.
I don't think my bumpers are mounted upside down. The center section is definitely correct, and the two side pieces wouldn't fit over the center where they overlap if they had been reversed. We did try flipping the overriders over top-to-bottom, and the fit was MUCH worse.
Orangener:
I guess my car could have Bavaria overriders - I haven't owned it since new. But regardless of where the parts came from, my intent is to use them, and make them fit as well as possible. The fit isn't terrible (well maybe it would be to a perfectionist) - I'd just like to improve it while things are apart.
That's a sharp looking E3 in your photo!
