Need Cylinder Head for my 74 3.0cs
Ohmess
I wanna DRIVE!
Aiken, SC
W&N has a shipping special today. Code bmw2017
You want a Schrick cam for your car.
Your head will be done next week.
Sadly I can't find a fuel pump for you. I may have thrown them away
I have the pump I pulled from my car sitting in the garage; I had to remove mine and change to an electric pump to make room for the triple webers.
scottevest
Ketchum, Idaho
Thanks. So, Don, can you let me know precisely what part no I need from w&n for the electric pump and cam stuff?
Ohmess
I wanna DRIVE!
Aiken, SC
Scott -- just so we are clear, my car has carbs and the pump I have is a mechanical pump. I saw your car was a CS and thought that this is what you were seeking.
Also, this will require a cam with the lobe to operate the pump. I believe the part I referenced on VAC Motorsports' web site has the lobe on it.
Best to check with Don on both of these things.
scottevest
Ketchum, Idaho
Don just talked to me and is going to ensure there is good CAM and electric pump when he sends to our shop to install. Yea!
How much better should she drive once this work is done?
I can't wait.
Ohmess
I wanna DRIVE!
Aiken, SC
Hey Steve - do you remember where the markings were on your cam? I recall some Schrick cams had identifying markings on the shaft; others on the end.
IPtRkJ5vszO3rwM8ZKiJTxeJjZeX3d-6VLSHrvMbJDOxu0rZIBdXX1xw4z8CRrCQSiEFD1lKFfR4nMe8Tb5Oyt4RXKUVQDxvqMulloJPXW5ASmcJ5vB6sx2G7mf3EX1588q5JGbDQy8KxykVFCU7OtEniMnu7Qa_XFIDLC2Y5vchV7es2SxIN2vcPTi9Frvak37Kl2t9eLZBJvYtZ06939Ijq1GrJ7GWCn-6zPAYbJnNZAlngJOTWonFGkGCs206c4KZJl_qFoLJxwiPbDlznv2hN9rc3A6RObIgg9vO09cfjNlY9sdw9ywyAc-h6AL2lczXaNrZuOaR_IzTgghk7yk1GWeuLwUBI9PWTxqPu0hV2k1GA6lxvm4W4NF208tOXwfP3M2cErmUEb2Ou_hhjXyz3XBrykThe-4L8qqGH3Xv6QfAQV5xTbMYcNACZ-DPk0hu32jsQmz0IrPZqNnC1KNr-MXZf6yCdZm2n_nIUujz7oif3S7Aqd-ba4LJY1OJV3NBVDlb1tjJiEWLK5GttWNDPI9ko_Mtk6u3HtMM9tJMSK-GBFrVQPQlrbGJloh77ekTuRB9ypK-lIzD532eD-hZJlm8PqKTFdk8_YRuZBBSvWE_w6KY=w1028-h771-no
sfdon
sfbay area
All cams are NLA from
Carl
VAC
W&N
Schrick NA
Expected (yeah right) this summer
I bought the last one today.
scottevest
Ketchum, Idaho
Carl
VAC
W&N
Schrick NA
Thank you very much
A problem finding the electric fuel pump as well or are we set?
rsporsche
Atlanta, GA
i heard something about schrick moved into the business of supplying OEM cams for some car manufacturer ... total change of business model, which doesn't help us.
Nicad
Toronto
If going with an electric fuel pump, make sure the mechanic installs either an oil pressure cutoff switch, an ignition cutoff and or an impact cutoff switch. This way it will stop pumping if you get in an accident or have a fuel leak after an impact.
Ohmess
I wanna DRIVE!
Aiken, SC
I used a revolution electronics relay. It pumps three seconds of fuel on start up, and cuts off flow if it doesn't get a signal from the coil.
sfdon
sfbay area
Stevehose to the rescue- he found what appears to be the second to last one- in Germany for our brother in Idaho.
The last one left is the strange motronic half moon model.
Thank you Steve!
scottevest
Ketchum, Idaho
Thank you Steve!
Thx!!!!!!
