Hey guys
Just to recap. Bought the car with an aftermarket monster tach. Removed it. OEM tach was non fonctionnal cause wiring disconnect and different engine in the car
Had the OEM tach modified to work with MSD ignition
Tach came back with same wiring and I want to use the wiring from the monster tach since I know it s working
I have 4 wires.
12V
ground
Light
signal
This is the back of the tach
I m a bit confused
The white strip in the middle shows 3 connectors
12V, for 12V power
one connector with the symbol (I) I guess for the computer signal
one connector with the negative sign (-)
top shows 1 wire
bottom shows 2
Can somebody point me where to connect ground and light considering I got 12V and signal right
Thx
I have 4 wires.
12V
ground
Light
signal
I m a bit confused
12V, for 12V power
top shows 1 wire
bottom shows 2
Thx
