Need your intelligence
aearch
Deceased
pleasant hill , ca
Can anyone identify
this hein werner jack
i need to get akit
to repair the leaking
thanks
alan
H-W jack
I have had a H-W Model "WS", 1 1/2 ton from 1975 which looks a little older than yours, and it works great. I never have had to rebuild it, yet. It does piddle once in a while and I have had to tighten the packing nut, check the fluid level and top up if necessary.
I have the "owners manual" and it lists the;
Kimmerle Brothers, 226 11th St., San Francisco
415-431-1163,
for sales and repair.
Check out this place, if you want to purchase a repair kit;
http://www.hcrcnow.com/shop/seal-kits/hein-werner
jack
what happened when i was injured was
i had a jack stand suporting the rear and it was in the dirt
and over days it fell forward
thats waht happened
i should have set the stand on concrete
Kit n caboodle
What model jack you have will determine which kit. Although it looks like your label is missing, mine is riveted on.
Maybe if you call the Kimmerle Bros. they can help you.
If using a jack stand on the ground, it better to cut a 1/2'' or 3/4'' plywood pad to use under the jack stand.
Too little too late
Duh never should have had it on the ground to begin with
i can send them a pic maybe they can identify it
i gOT it from and old man who did lawnmover repair 30 years ago
