Thanks for all the great ideas.
The car only makes the sound when I brake, and then the sound can remain for a few seconds after I let off the brakes; that's how I managed to get it on video. Normally, there is no sound until I hit the brakes hard. It was just dumb luck that I got it on video.
The sound happens if I use the foot brake or the e-brake.
No indication of scaring on the radiator or fan, so if the motor is moving forward due to bad mounts it isnt moving much.
Turning makes no difference.
I pulled the wheel and caliper off and there was nothing stuck that I could see. Caliper is torqued on per the manual.
Readjusted the e-brake shoes. No help. But I didn't adjust the cable, only the shoes. Not sure if that matters.
I replaced that outer CV joint a week or two ago. Maybe the clip at the end of the axle which keeps the CV joint on came loose and is floating around in there. That doesnt seem to explain why the noise only happens when braking. I really hope I didnt screw-up that dirty job.
It just occurred to me that around the same time I re-installed the guibo (the last shop did not align it correctly). Maybe those bolts came loose.
