I see some corrosion on the rear brake line, so will be replacing all of it and the fuel line. I am assuming you cannot buy brake lines that are preformed and must bend them to fit? DOes anyone have any tips on how to best do this? I thought I would cut my existing line in two foot sections and use these sections to help bend the new line a bit at a time. Should I just buy shorter lines and attach them together with fittings or attempt to do a one piece line from master to the rear? I have never used a flaring tool, so if anyone knows which type of flare the E9 uses that would be helpful. I suppose I could reuse the fittings.
Tia
Tia
